  2. Functional Verification
  3. how to instantiate verilog module in vhdl top level
  • Subscribers 67
  • Views 19501
SUBBHAREDDY
SUBBHAREDDY over 17 years ago
Hi
I want to instantiate verilog module written in verilog.
Now my top level is vhdl.I want to instantiate inv.
Here below i had written simple verilog code :
`timescale 1ns/1ns
module INVERTER (IN, OUT);
output OUT;
input IN;
assign OUT = ~IN;
endmodule// INVERTER
Now want to simulate this verilog code in vhdl.
 How can i do it.
 Pls help me out to resolve this issue.
Thanks and regards
Subbhareddy
  • Hilmar
    Hilmar over 17 years ago
     Hi Subbhareddy,
    You can do that using component instantiation. I redid your inverter slightly to remove the VHDL in and out keywords:
     module inv(i,o);
    output o;
    input i;
    assign o = ~i;
    endmodule
    Then I wrote a tiny entity/architecture to use the module:
    entity e is
    end e;
    architecture a of e is
    component inv
    port (i: in bit; o: out bit);
    end component;
    signal my_in, my_out : bit;
    begin
    i : inv port map (i=>my_in,o=>my_out);
    end a;
    If you compile and elaborate it and start it up in ius/simvision, you'll see the inverter component instantiated in the architecture.
    Best regards,
    Hilmar
