  2. Functional Verification
  3. verilog divider
  • Subscribers 67
  • Views 15327
verilog divider
andyandy
andyandy over 17 years ago
 I have small problem.............with synthesis.
during synthesis  synthezer create too much registerlicznik, how can I repair it?
 module dzielnik(
     clk_i,
     rst_i,
     led_o
parameter N   = 50000;
parameter RESET_VALUE = 0;
input  clk_i;
input rst_i;
output led_o;
reg led_o=0;
reg [N+1:0] licznik=0;    //tu jest problem
always @ (posedge clk_i or posedge rst_i)
begin
  if (rst_i)
      begin// reset synchronczny
   led_o<= RESET_VALUE;
   licznik<=0;
   end
  else
      begin
      licznik<=licznik+1;
          if(licznik==N/2-1)
          led_o<=~led_o;
          else if (licznik==N-1)
            begin
            licznik<=0;
            led_o<=~led_o;
        end
        end
end
endmodule
  • Shalom B
    Shalom B over 17 years ago
    You've written a counter with 50002 bits. It seems you only wanted a counter that can count up to 50000, which is not the same. 16 bits would be enough.
    Shalom
