  2. Functional Verification
  3. writebn_sn
  • Subscribers 67
  • Views 14741
writebn_sn
SpecMAN INFANT
SpecMAN INFANT over 17 years ago
  Can anyone explain what the specman component writebn_sn exactly does?
eg.  registers.writebn_sn(value,byteen)   (The value and byteen are predefined values)
Thanks in Advance
Specman baby
  • Hilmar
    Hilmar over 17 years ago
    This looks like a plain method call in some struct/unit that, looking at the name, does something with registers. Looking at the naming, it's some sort of write method that does something with a value and byte enables, but that's just a guess. Where do you find this code? It's as far as I know not something built-in, so it looks like you'll need to look at the components imported in your environment.
    If you'd like some on-site assistance on this, I would recommend contacting a local Cadence AE.
    Good luck,
    Hilmar
