  2. Functional Verification
  3. Type Narrowing
  • Subscribers 67
  • Views 14759
Type Narrowing
MVSI
MVSI over 17 years ago
Hi I need to change this: read_only(config.as_a(MASTER agent_config_u).temp); using type narrowing method. Please suggest me How to change it. Thanks!
  • StephenH
    StephenH over 17 years ago
    Hi MVSI.
    I recommend opening the help browser via the "sn_help.sh" command, and searching for "type narrowing" - the first result should get you moving along.
    Basically though you'd just need to change your example to add a line:
    keep config is a MASTER agent_config_u;
    Then change your example constraintto something like:"read_only(config.temp)"
    You don't say why you "need" to make this change though. Use caution in case you are making your code less flexible or less reusable by doing this change...
