  2. Functional Verification
  3. Instance handeling during simulation
  • Subscribers 67
  • Views 14777
WorkMan
WorkMan over 17 years ago
I am in the gate level power simulation phase. I have multiple (X100) instances of the same module and I do not want to run all of them as gate level modules just the ones I'm interested in capturing there signals. The only way I know how to do it is during compile time using `define. The problem is that we want to hold a single compiled design and not to have to compile each test again according to the test designer needs.
I would like to know if there is a way to define the instance module type during the simulator initial stages. Maybe SystemVerilog (Which I have no deep knowledge about) have an option to do so. I have tried using the $test$plusargs to differ between the different instances but it does not compile.
Thank you,
  • asedehi99
    asedehi99 over 17 years ago
    hey workman; did you ever find a solutio?
