  2. Functional Verification
  3. Calling sequence form Test case
  • Subscribers 67
  • Views 14844
SpecMAN INFANT
SpecMAN INFANT over 17 years ago
  Suppose I have a list in a Test Case. Now if I am calling a sequence from that test Case will the memory be passed to the sequence also?
For eg:
---Test Case---
extend main master_sequence
Memory_define : list of uint;
body() @driver.clock is only {
--inside test case body--
do virtual_sequence;
Now inside virtual_sequence body can I access this  Memory_define list directly without passsing it as any argument?
Specman Baby
  • Hilmar
    Hilmar over 17 years ago
    The easiest approach would be to extend your sub-sequence with a reference to the parent sequence type, and access the list through this reference. Basically the usual struct referencing. Do keep an eye on how you structure your sequences and the validity of the data. During the do of the subsequence, the parent sequence's list might change, depending on your environment and requirements, so keep this in mind when adapting your sequences!
    Good luck,
    Hilmar
