  2. Functional Verification
  3. IUS 6.11 USR3 - worklib is not updated after compiling
  • Subscribers 66
  • Views 1000
haikom
haikom over 16 years ago
I installed the nclaunch version 6.11 at a linux machine (RedHat 4 Enterprise Ed.). After this I configured the product so that all vhdl std. libraries where compiled. When I try to compile vhdl or verilog code, there is no change in the worklib (no '+' at the left side of the worklib)!!! The older version (IUS 5.7) worked whithout problems.
Does someone has an idea, what causes this problem?
Kind regards
haikom
  • haikom
    Hi all,
    the problem seems to be solved. I looked at the environment variables an saw, that there were two entries:
    "$IUSDIR/tools/nclaunch/bin/64bit" AND "$IUSDIR/tools/bin"
    After I removed the first entry, the problem with the non-updated worklib was solved. The I looked into the install.pdf and there is written, that only the "instDIR/tools/bin"  path has to be added to the PATH variable. So this was my fault :)
     Regards
    haikom
