  2. Functional Verification
  3. Division Problem
  • Subscribers 67
  • Views 20058
Division Problem
karlsmartin
karlsmartin over 17 years ago
Hi all,
 I have a problem with the division of a real number, for example dividing 45546 with 10000. The expected value would be 4.5546. But as a result I get 4.5545999999998. Is there a workaround for this problem?
integer v_int;
real v_real;
initial begin
  v_int = 45546;
  v_real = v_int/10000;
end
martin
  • tpylant
    tpylant over 17 years ago
    It might be because you divided an integer by an integer. Here is the code I used which generated 4.554600 for v_real:
    module test;
      integer v_int;
      real v_real;
      initial begin
        v_int = 45546;
        v_real = v_int/10000.0;
        $display("%f", v_real);
      end
    endmodule
    Tim
  • karlsmartin
    Hello Tim,
    Thanks a lot for your answer. With the integer divided by an integer you are completly right. Unfortunately I forgot in my example the $itor systme task I'm using.
    The thing is, that I have a discrepance between the $display-output in the console and the waveform-output. Looks like the $display is rounding the result to 6 digits after the point and not prinitng the value which the simulator is handling. Even when I hard assign the value to v_real = 4.5546 I get a discrepance, due to the reason that a real "real-value" doesn't exist. My question is if I can tell the simulator only to have a accuracy of 4 digits after the point. I tried to convert the real-value to bits and to cut of some of the last bits. But this is not really working.
    martin
  • tpylant
    I could not see the discrepancy you had.
    Here is something using SystemVerilog string function that might help you with keeping the precision to 4 places:
    module test;
      integer v_int;
      real v_real, v4_real;
      string v_string;
      initial begin
        v_int = 455461;
        v_real = v_int/100000.0;
        #10 ;
        v_string.realtoa(v_real);
        $display("%f  %s", v_real, v_string);
        #10 ;
        v_string = v_string.substr(0,v_string.len()-2);
        #10 ;
        v4_real = v_string.atoreal();
        $display("%f  %f", v_real, v4_real);
        #10 ;
        $finish();
      end
    endmodule
    Tim
  • karlsmartin
    Hi Tim,
    if you move the cursor above the value on the left hand side, you can see the discrepance. Maybe I'm wrong but I think this is the most accurate value the simulator is able to use. Due to the accuracy of a floating point number.
    Anyway, the example you posted is helping me with my problem and working fine. Thanks you very much, it really helps me a lot.
    martin
