  2. Functional Verification
  3. Simulation problem: unwanted zero-width glitch
  • Subscribers 68
  • Views 23272
ridgemao
ridgemao over 17 years ago
I'm using LDV 5.1. In simvision's waveform window, many signals have zero-width glitch. How can I avoid displaying these glitches? I know it is due to the zero-time delay of sequential logic in functional simulation, and these "zero-width glitch" won't appears in actual application because there is no zero-time delay in actual sequential logic. And I think the simulator knows all about it and It marks the "zero-width glitch" with a special sign. I don't want the simulator to display these glitches, how can I make it? Thanks.
  • ridgemao
    here is a snapshot of my waveform. The zero-width glitch have a special mark, I don't want to display this kind of glitch. http://picasaweb.google.com/lh/photo/frI8o_RwPqxbRX_YCj6Kkw?feat=directlink
  • adua
    adua over 17 years ago
    You need to turn off "-event" switch when you are opening the shm waveform database. The default behavior is not to record these glitches (that you want), and it happens only when you specify "-event" option of 'database' tcl command.
    The following is copy-paste from NCVLOG product documentation (<ius_inst_dir>/doc/ncvlog/ncvlog.pdf ) on "-event" option of database
    database Command Modifiers and Options
     -event
    Dumps all value changes to the database.
    By default, when probing to an SHM database, the simulator discards multiple value changes for an object during one simulation time and dumps only the final value at the end of that simulation time. Use -event if you want to dump all value changes to the SHM database. You can then use the SimVision waveform viewer to expand a single moment of simulation time to show the sequence of value changes that occurred at that time.
  • Shalom B
    Shalom B over 17 years ago
    As a side-note, sometimes one sees behavior that seems inexplicable, such as a flip-flop whose output changes although its data input looks constant all the time. In such cases, one should suspect a zero-width glitch and turn on -event. I had such a case just recently.
    Shalom
