  2. Functional Verification
  3. ncvlog: *E,RIMPCD: error reading implicit cds.lib
  • Subscribers 66
  • Views 3354
AshVarma
AshVarma over 17 years ago
IUS version 08.20-p001
I am getting this error in compiling through irun when I use a Verilog file as -v.
ncvlog: *E,RIMPCD: error reading implicit cds.lib file: /lan/work_xt/INCA_libs/cds.lib (Library redefined).
If It include the file directly, it doesn't complain.
-ashutosh
  • tpylant
    tpylant over 17 years ago
    Use the following command to make reset the session to make sure nothing was corrupted:
    % irun -clean
    This will clean out the INCA_libs and let you start from scratch for your compilation.
    Tim
  • AshVarma
    This doesn't help. I have tried after cleaning up everything, blowing away INCA_libs etc.
  • Mickey
    Mickey over 17 years ago
    Not sure what the problem is here.  Can you answer the following questions?
    does your command line have a -cdslib instruction?
    does the -v directory contain a cdsinfo.tag or cds.lib file?
    Best regards,
    Mickey
  • AshVarma
    No, I am simply compiling a bunch of Verilog source code as:
    irun <source_files> -v <lib_files>
    irun is managing all cds.lib etc and coming up with this error.
    -ashutosh
