  2. Functional Verification
  3. regardin "posedge clk iff rst == 0 " in system verilog
  • Subscribers 67
  • Views 5010
onkarkk
onkarkk over 17 years ago
Hi ,
I am new to systemverilog , i want to learn and implement one of my block in systemverilog. While going through it i am getting many doubts ... I am trying a alot to understand , some times it is killing lot of time .. (may be they are simple or serious i dont want to leave like that )..
Here is one of such things :
what is the difference between   always @ (posedge clk iff rst == 0 or posedge rst)
always @ (posedge clk or posedge rst)
i.e.,
theory wise i understood from LRM , but implementation wise after synthesis will it produce different circuit ??
If i am going in wrong direction please correct me ..
Thanks in advance,
regards
Krishna Kishore
  • Shalom B
    Shalom B over 17 years ago
    Simple.
     "iff" is not synthesizable.
    Shalom
  • onkarkk
    Thankyou Shalom,
    So then if it is not synthesizable whats the use of this ?? i.e., where  exactly the synthesis simulation mismatch misguiding will be detected by this will be advantegeous to the user or verification engineer..
    Please correct me if my interpretation/approach is going away from the topic..
     Thanks in advance,
    regards
    Krishna Kishore
  • Shalom B
    "iff" is synthesizable in principle, but today it is not yet supported by most tools that perform synthesis.
     Shalom
  • onkarkk
    So, If it is synthesizable what would be the expected circuit?? What is the significance of it?
    Thanks in advance,
    Krishna Kishore
