  2. Functional Verification
  3. Disable Statements in NCVLOG
  • Subscribers 67
  • Views 17081
anshman
anshman over 17 years ago
 I am using diable statements in the fork, join_none statments, after sometime I want to disable all the threads which were started by fork but it is not working.
example:
 fork:label
    run.run_forever_t();
    begin
        #199;
        disable label;
    end
join_none:label
 in the above example task run_forever_t should stop after 199ns after fork was exercised but it keeps running,
Regards
Anshuman
  • Shalom B
    Shalom B over 17 years ago
    Try "disable fork;"
     Shalom
  • anshman
     I have tried it, it is not woking.
    Anshuman
  • StephenH
    StephenH over 17 years ago
    The disable only affect sub-processes in the current fork, so the code you've written is not right for what you're trying to do.
    You should instead do something like this, which I tested:
    module background;
    task run_forever_t;
      forever #10 $display("tick");
    endtask
    initial begin
      $display("start");
      fork
        begin : background_process
          fork
            run_forever_t();
            #199;
          join_any;  // join after either thread finishes
          $display("tock");
          disable fork;  // kill the threads that haven't finished
        end : background_process
      join_none;
      #100;
      $display("Stopped");
    end
    endmodule
    The outer fork allows the whole thing to run in the background, which I believe was your original intention.
    The inner fork is needed so that the disable can kill off the run_forever() task.
    Hope this helps.
    Steve.
  • anshman
     Thanks !
    It worked fine.
     Regards
    Anshuman
  • asedehi99
    asedehi99 over 17 years ago
    thanks guys...that did help
