  2. Functional Verification
  3. merging code coverage from different design databases
  • Subscribers 68
  • Views 23058
perezi
perezi over 17 years ago
 I searched for similar posts but did not find an answer to what I'm looking for, so I'm asking for some info on code coverage.
I would like to merge test results from different simulation runs, each from it's own testbench environment.   I ran different regression tests, two for subsystem and one for the chip level.  I was able to merge all the test results for each subsystem and chip level tests, but now I want to merge the subsystem results into the chip level results to see the overall code coverage?  This is needed since subsystem tests were not replicated at the chip level.  Only a subset and some new tests were used.
 Regression runs
1. Testbench hierarchy tb.subsystemA (chip level hieararchy i_chip.i_subsystemA)
    The coverage results for module subsystemA were merged to tb1/cov_work/i_subsystemA/all
2. Testbench hierarchy tb.subsystemB (chip level hieararchy i_chip.i_subsystemB)
    The coverage results for module subsystemB were merged to tb2/cov_work/i_subsystemB/all
3. tb.i_chip
    The coverage results for chip were merged to tb3/cov_work/i_chip/all
Now I need to merge these 3 merged results into one merged database?  Is that possible?  Or do I need start from the source tests files?  The problem I get is with the model file being different.
Even merging different subsystem tests into the chip level gives me a model error.
failed due to mismatch in design checksum with the loaded model file "cov_work/i_chip/all/70938af1_63e43f52.ucm".
Thanks in advance.
  • nlin
    nlin over 17 years ago
     In order to merge the coverage databases, you'll need to set the DUT to merge and use the merge iccr command.
     i.e.
    set_dut_modules subSystemA subSystemB
    This is if subSystemA and subSystemB are the actual module names of the blocks instantiated inside the chip  which you want to merge
    Then use the merge command to merge all the tests
     merge tb3/cov_work/i_chip/all tb1/cov_work/i_subsystemA/all tb2/cov_work/i_subsystemB/all -output combined
     The merged output will be dumped in the directory tb3/cov_work/i_chip/combined
      You can reference either the quick reference manual
     http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccquick/iccquick8.2/examples/iccqrg.pdf
    or the full user guide
     http://sourcelink.cadence.com/docs/files/Release_Info/Docs/iccug/iccug8.2/iccugTOC.html;jsessionidsl=CAFMRW2DZ2MKTLA0BEBCFEQ
     for the detail description of these commands.
     If you are still seeing problems, just reply to the thread, and I will respond to you.
     BTW, in the future, if you run into any issues with Cadence tools, you can file a ticket to Cadence Support from http://sourcelink.cadence.com
    Nancy
