  2. Functional Verification
  3. Async signal assetions
  • Subscribers 66
  • Views 14817
SVA1
SVA1 over 17 years ago
There is one async signal a_sync, this signal needs to be stable till first incoming clk.  a_sync signal may get change any time irrespective to clk.
I have written property as follows, it works fine for single bit, but for multibit a_sync signal I need help.
property abc(a_sync, clk);
 int temp_val;
  @(a_sync) (1,temp_val = ~a_sync /*inverse because previous value will be sampled*/ ) ##1
   @(posedge clk) (temp_val === a_sync);
endproperty
This wont work for multibit signal. How can we do for multibit. There are many such signal, so I want to write generic assetion property.
-Kunal
  • JoergM
    JoergM over 17 years ago
    Hi Kunal,
    pretty much code for a simple behavior. Did you consider PSL for this property? PSL has 2 advantages: unclocked properties and initial properties. Example:
    abc: assert stable(a_sync) until(clk);
    It would be evaluated each time an event on a_sync or clk occurs. I assume this is the behavior you describe?
     Joerg.
