  2. Functional Verification
  3. FSM coverage and generate block
  • Subscribers 67
  • Views 16218
karlsmartin
karlsmartin over 17 years ago
Hi all,
I'm doing a coverage for a simple FSM. A generate block is analyzing the state of the FSM. The ICC is extracting the real FSM and one for every block in the generate statement. For example:
generate for (i=1; i<=12; i=i+1)
    if (state[i]) begin
This way I get 13 state machines extracted and only for the real one and the last block I get coverage data. This way my coverage is only 100 / (i+1) % of the real coverage.
Is there any possibility to get rid of this problem.
martin
  • StephenH
    StephenH over 17 years ago
    For the record, I've contacted Martin off-line to discuss the specifics of his design, but I thought I'd share a more generic comment with the forum at large.
    Design practices generally recommend to code FSMs in 1 or 2 processes; and the coverage algorithms in IUS identify FSMs based on these design templates.If you code the output logic using a generate loop, as Martin described, then each iteration of the loop creates a new process or always block. This is functionally correct but contravenes the 1-or-2-process guideline. This leads to the coverage system becoming confused about the user's intentions.
    One could almost certainly replace the generate loop with a single always block, which might be easier to read and would avoid the extra bit of hierarchy that a generate statement introduces.
