  2. Functional Verification
  3. test to write and read registers with field order like packing...
  • Subscribers 67
  • Views 14639
test to write and read registers with field order like packing.low
mkyang
mkyang over 17 years ago
Please, tell me how to test registers when the filed order of a register is packing.low, from a low bit position to a high bit position.
I applied the following code by referencing the document 'The Register and Memorr Model', but I could not get correct result.
extend MY_REG vr_ad_reg_file {
keep packing_mode == packing.low;
extend MAIN vr_ad_sequence {
!rgf_seq : ALL_REGS_IN_FILE vr_ad_sequence;
body() @driver.clock is {
do rgf_seq keeping {
.reg_file == MY_REG;
.order == ASCENDING;
.direction == WRITE
But, it seems not writing values correctly to registers.
  • StephenH
    StephenH over 17 years ago
    This should work, but applies to an entire register file, not individual registers (looks like you knew that already, but I thought it was worth mentioning).
    It's impossible to know what's wrong from your description. Can you give more detail about the symptoms?
    You say that "[vr_ad is] not writing values correctly to the registers"; can you provide a concrete example please?
    1. What values do the individual fields show in the vr_ad_reg when it's generated by the sequence?
    2. What is the hex value of the bus data when vr_ad_execute_op() is called?
      Hint: set a break point on the vr_ad_execute_op() method in your bus eVC's hook-up file.
    3. Does the vr_ad hook-up to your bus eVC handle the data correctly?
