  2. Functional Verification
  3. NCsim and SystemVerilog issue
  • Subscribers 67
  • Views 15285
navis
navis over 17 years ago
 Hello all,
I have follow problem using SystemVerilog.
I'm writing some testbench. My test bench has some input and outputs ports. Thiese ports are delcared as a "logic". My class that handling this ports can't drive inputs and outputs. I beleive this ports should be interpreted as a global variables, and should be accessible by my class methods. But in practice this not happening.
Could someone have some ideas why this is happen.
Best regards and thanks
  • tpylant
    tpylant over 17 years ago
    Does this represent what you are asking about:
    module tb(input logic in, output logic out);
    endmodule
    class a_c;
      bit a, b;
      function new();
        a = in;
        b = out;
      endfunction
    endclass
    Tim
  • tpylant
    BTW, this does work:
    class a_c;
      bit a, b;
      function new();
        a = 0;
        update();
      endfunction
      function void update();
        a   = in;
        b   = a;
        out = b;
      endfunction
    endclass
    a_c a = new();
    assign #1 in = ~out;
    always @(in) begin
        a.update();
    end
    initial begin
      $monitor($time,,in,,out);
      #10 $finish;
    end
    endmodule
    Tim
