  2. Functional Verification
  3. Continue_error
  • Subscribers 68
  • Views 15286
Continue_error
SpecMAN INFANT
SpecMAN INFANT over 17 years ago
Simple Qn.    Does anyone know the command to continue running a testcase even if there are dut errors? also where in the test case should this be inserted?
Thanx
Specman Baby
  • MVSI
    MVSI over 17 years ago
    Hi, Try this way... extend sys { setup() is also { set_check("...",WARNING); }; };
  • SpecMAN INFANT
     Hi
    Thanks for the reply. Is there any way in which a dut_error can be flagged instead of warning and continue so that at the end the total no. of dut_errors can be seen instead of breaking at the first error itself
    Specman Baby
  • MVSI
    You can use ERROR_CONTINUE also instead of WARNING. In both the cases execution will continue. With WARNING, it will increment num_of_dut_warnings and with ERROR_CONTINUE, it will increment num_of_dut_errors. At the end of the simulation, it will show num. of dut warnings/errors
