  2. Functional Verification
  3. Greping all loaded e modules for a regular expression
  • Subscribers 67
  • Views 15274
avidane
avidane over 17 years ago
Can anyone think of a good reason why Specman's "search" command won't take a regular expression to look for in the loaded e modules? Before I code my own script to do this, if anyone has already gone down this path and can share the code I would be grateful...
Thanks a lot,
Avidan Efody
  • StephenH
    StephenH over 17 years ago
     Hi Avidan.
    If you're using the SimVision front-end for Specman, then you certainly can do a regexp match over the loaded files.
    Go to SimVision's "Verification->e source searcher" menu and select "grep" when searching.
    I thought it was possible in the old specview GUI as well, but I'm not in a position to try that out right now.
    Hope this helps :-)
  • avidane
    Thanks a lot, I haven't been to Specman for a while, and discovered the search GUI only after I put this post.
    But in any case, I guess it would have been nicer to have this through a command line interface as well...
