  2. Functional Verification
  3. Specman syntax errors
  • Subscribers 67
  • Views 16327
Sarathi
Sarathi over 17 years ago
Hi Stephen Thanks for the previous help. I tried it and it worked with the latest versions of Specman as well. I have a new problem. I am trying to run DV using specman but I get a lot of syntax errors when I load the e-code in the specman environment. I used all the following Specman versions v4.3.1, v5.03, v5.1, v08.10.001, v08.20.002 and I tried running on both LINUX and SOLARIS as well. All of them gave the syntax errors The syntax errors are due to the following coding style: operate: ... ... end; All the action block statements have the similar syntax of ": ... end;" instead of "{...};" Can you identify the syntax used? Which version of Specman will it work with? Regards Bharath StephenH wrote: > > Hi Sarathi. > > It sounds like you've instantiated all your verification code directly > in sys, is that correct? > Cadence does not recommend this approach as it makes the code harder > to re-use between projects and from block to system level. > Instead you should encapsulate your testbench code in at least one > unit that you then instantiate inside sys. > > If all your code currently is written like this: > extend sys { > event clk is rise('clock') @sim; > ... > }; > > You could fairly easily change to swap "sys" to another unit name, > like this: > unit tb like any_unit { }; > extend tb { // instead of sys > event clk is rise('clock') @sim; > ... > }; > extend sys { // new block of code > tb : tb is instance; > keep tb.hdl_path() == "~/"; > }; > > This might still need some tweaking for your testbench coding style if > you used any full hierarchical paths from sys, but it's definitely the > right direction to be moving in. > > If you get really stuck, file a service request through SourceLink, > and one of hte support team would be able to help you without you > having to share any details of your code in this public forum... > > Good luck! :-) > > Steve. > > > > -- > View this message online at: > www.cadence.com:443/.../16151.aspx > -- > You received this email because you subscribed to notifications for > the Cadence Functional Verification Forum. To unsubscribe, log in, go > to forums, and change your forum subscriptions. > > www.cadence.com/.../ForumSubscriptions.aspx
  • StephenH
    StephenH over 17 years ago
    the syntax errors
    Yes, I am not surprised that they all give the same syntax error!
    operate:
    end;
    instead of "{...};"
    This is not valid e syntax, which is why Specman issues a syntax error. Did you write the code or has it come from someone else who you can ask about the code's origins? I certainly don't recognise this syntax, and it won't work with any known version of Specman.
    Without seeing the rest of the code, I can't say whether this will work, but it if it genuine e code apart from the ": ... end;" then you might try just swapping the ":" to "{" and "end;" to "}".
    Good luck!
  • Sarathi
    Hi Stephen,
    The code was developed way back. I found some document that says that it
    uses Specman 2.0. Is this version still supported or used anywhere?
    Regards
    Bharath
    StephenH wrote:
    > *Sarathi:*
    > environment.
    > gave
    > the syntax errors
    > *Sarathi:*
    > operate:
    > end;
    > end;"
    > instead of "{...};"
    > Good luck!
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
  • StephenH
    The information about supported tool versions can be found on the SourceLink web site:
    http://sourcelink.cadence.com/en/infomgmt/DisplayStaticLink.jhtml?/docs/files/lifecycle/EORsupported.html
    This shows that Specman 6.0 is the oldest version still supported by Cadence.
    Version 2.0 pre-dates my career with Verisity, so I cannot comment on the syntax from that version!
