  2. Functional Verification
  3. Wait for a specific delay
  • Subscribers 67
  • Views 17901
SpecMAN INFANT
SpecMAN INFANT over 17 years ago
 Is it not possible to wait for a variable defined delay in Specman.
eg:
gen time_delay;
wait delay(time_delay ms);
However, the above lines reult in "Unrecognised exprexxio" Error.
Have any of you come across this before?
Specman Baby
  • Hilmar
    Hilmar over 17 years ago
     Hi!
    The issue you're seeing is the fact that you're using a uint (or whichever numerical type) and a time denominator (ms here) to specify the delay, which basically takes a uint. The time type in my view is just a special numerical type. So you can do two things:
    1) Use a var (or struct member) of type time and gen that, feeding it to delay() without the time denominator.
    2) If the ms granularity is of imporance, do something like this:
      var one_ms : time = 1 ms;
      gen time_delay;
      time_delay *= one_ms; //multiply with 1 ms granularity...
      wait delay(time_delay);
    I'd say that should sort things out. Let me know if there's another issue (you can reach me directly by picking my first name at cadence.com).
    Good luck,
    Hilmar
  • StephenH
    StephenH over 17 years ago
    I'd add a small word of warning to this topic: asking for a "wait delay" does have a performance impact, because a callback has to be registered for the delay. If you only call the delay fairly infrequently it should not be a problem, but if you call wait delay too often (e.g. on every clock egde) then the simulation performance can be impacted.
    So use it with care, and if possible use some event-based delay mechanism rather than time-based.
