  2. Functional Verification
  3. OVM: Unable to change objects default configuration
  • Subscribers 68
  • Views 15247
JanP
JanP over 17 years ago
Hi all,
I am just building a verification environment pretty similar to one in the XBUS examble.
I've got problems override a default values of user-configurable variables using configuration interface (set_config_int method).
My top level object cmux_tb instatiates enviroment switch_env (an OVC) and configures it:
class cmux_tb extends ovm_env;
  `ovm_component_utils(cmux_tb)
  // the Switch environment
  switch_env cmux_env;
  virtual function void build();
    super.build();
    set_config_int("cmux_env", "num_inputs", 3);
    set_config_int("cmux_env", "num_outputs", 1);
    set_config_int("cmux_env", "bus_width", 1);
    set_config_int("cmux_env", "ctrl_width", 2);
    cmux_env = switch_env::type_id::create("cmux_env", this);
  endfunction : build
endclass : cmux_tb
The switch_env has defined (and registerred in a Factory) the above mentioned varibles:
class switch_env extends ovm_env;
  // environment properties
  protected int unsigned  num_inputs = 0;
  protected int unsigned  num_outputs = 0;
  protected int unsigned  bus_width = 0;
  protected int unsigned  ctrl_width = 0;
 `ovm_component_utils_begin(switch_env)
    `ovm_field_int(num_inputs, OVM_ALL_ON)
    `ovm_field_int(num_outputs, OVM_ALL_ON)
    `ovm_field_int(bus_width, OVM_ALL_ON)
    `ovm_field_int(ctrl_width, OVM_ALL_ON)
  `ovm_component_utils_end
endclass : switch_env
When I print the topology after elaboration, I realize, that those varibles remains set to 0. When I use the same approach to object instatiated inside switch_env, the configuration works fine.
Can somebody tell me what I am doing wrong?
Thanks for help,
Jan
  • avidane
    avidane over 17 years ago
    Hi Jan,
    One very common source for these kind of problems is forgetting to place a call to super.build() in the class that you're configuring. Maybe you overrode the build() function in switch_env but didn't call super.build() there?
    Other than that your code looks perfectly fine to me...
    As a side note, I think you'll get much quicker responses at the ovmworld forum. Traffic there is much higher and only OVM related...
     Avidan Efody
     www.specman-verification.com
  • JanP
     Hi Avidan,
    YES, that was it. Even if I know this and I checked my code thousand of times before I place my post here, I didn't notice it, 'developers blindness' ;-).
    Thank you very much.
    JanP
