  2. Functional Verification
  3. Active/Reactive regions
  • Subscribers 67
  • Views 3175
Leo1008
Leo1008 over 17 years ago
 I have often come across the terms active and reactive regions of simulation in many of the SV tutorials, but haven't figured what they actually mean yet. Can you please elaborate on these.
  • tpylant
    tpylant over 17 years ago
    The reactive region is a new region added with SV that allows for sampling (especially with the use of assertions) to occur before any blocking, NBA, and continuous assignments are performed.
    Tim
  • hipooja
    hipooja over 17 years ago
    Tim,
    Does'nt the Reactive region come into picture after the blocking and non-blocking assignments have been done in the
    stratified event queue? I understand that the reactive region comes after the active region and programs work in the reactive region of the queue so that by that time all blocking ,non-blocking and continous assignments have been evaluated.
     Please correct me if i wrong --The active region is the region where the continous assignments , blocking assignents and non-blocking assignments are evaluated in order specified above.The assertions execute in the observed region which follows after the NBA are evaluated and assigned,the reactive region follows the observed region where the 'program' block comes into picture.The testcase is written in the 'program' block and this is because by that time all continous assignemnts , blocking and non-blocking assignments have been evaluated and assigned and this avoids user induced races.
    Pooja Vaishnav
  • tpylant
    Yes, I wasn’t clear and you are correct. The reactive region comes after NBA, blocking assignments and continuos assignments. However, in the case of assertions it uses that values that were sampled before those events.
    Program blocks also work in the reactive region. I’m not sure if the 1800-2009 standard addressed program blocks, but I know there were originally many issues in using program blocks because of inconsistencies in the LRM and how they were supposed to be implemented. Since OVM does not require the use of program blocks, this has not been a concern.
    Tim
