  2. Functional Verification
  3. Ref to variables
  • Subscribers 67
  • Views 15161
Ref to variables
Leo1008
Leo1008 over 17 years ago
I wanted to know if I can pass, to a class method , references of variables not defined in that class??
Insiya
  • hipooja
    hipooja over 17 years ago
    I do not think you can pass a variable which is not defined in the class ,to its method.This is because the class must know beforehand the type of the variable (I think)
    For example when you pass the channel handle to the constructor of the driver ,you need to define the channel handle before utilizing it.Oki let me put up a pseudo code for this
    Top
    class env_top extends vmm_env {
    virtual function build() {
    vmm_channel channel = new():
    //The channel connects the gen and driver.
    gen = new(channel);
    drv = new (channel) ;
    } //end build
    class atm_drv extends vmm_xactor
     vmm_channel channel_drv;
      function new(vmm_channel channel) {
       if(channel == null ) channel = new;
       this.channel_drv = channel;
    } //end function new
    //Usage
    virtual task main () {
     this.channel_drv.peek_t(vmm_data transaction)
     @posedge clk
     ----driver code
    } //end of main
       Note : the code is not correct syntactiacally.
    Pooja
  • tpylant
    tpylant over 17 years ago
    Anything you want the class to use that is outside of the class needs to be passed into the class via the new constructor.
    class foo;
      int a;
      function new(int in);
        a = in;
      endfunction
    endclass
    module test;
      foo f;
      initial f = new(10); // the value 10 is passed into the class
    endmodule
    Tim
  • Leo1008
    Leo1008 over 16 years ago
    Thanks Pooja and thanks Tim.
    Even I was thinking that may be I could pass something not defined in the class via the new constructor. Now I am sure :).
    Insiya
