  2. Functional Verification
  3. Error- uninitialized virtual interface object
  • Subscribers 68
  • Views 10903
akshay jog
akshay jog over 16 years ago
hi, I have following error when simulating some ovm code "uninitialized virtual interface object" Can some one explain to me , what does this error mean and how to fix it?? after this error message it shows me the line in my code so pasting that part of code as well //***************************** virtual task reset_signals(); @(negedge vmif.i_aresetn); // error at this line----------------------- //write address signals vmif.i_awid_m
  • avidane
    avidane over 16 years ago
    A virtual interface is actually an uninitialized pointer that must always be connected to some real interface instance before it can be used. In your case you most probably didn't initalize the virtual interface.
    interface x();
    bit y;
    endinteface
    module y();
    class z;
    virtual interface x x_vif;
    endclass
    // actual interface instance
    x x_if();
    initial
      begin
        z z_i = new();
        z_i.x_vif = x_if;
      end
    endmodule
    Avidan Efody
    Verifigen
    www.specman-verification.com
