  2. Functional Verification
  3. event questions from newbie
  • Subscribers 66
  • Views 14554
enchanterchi
enchanterchi over 16 years ago
Dear Sir/Madam: I am a newbie of verification and specman. I have a question about EVENT in specman e: Can I create a event with is consisted of some other event, such as event CONSISTED_e = (@start_e or @stop_e or @clock_rise)? If it is possible, how could identify which is the cause of the CONSISTED_e in code? For example: my_method () @CONSISTED_e is { if (CONSISED_e is caused by @start_e) { // do something }; if (CONSISTED_e is caused by @(stop_e) { // DO SOMETHING }; and so on. Thanks.
  • Hilmar
    Hilmar over 16 years ago
    To answer your syntax question: Yes, you can declare events as combinations and/or sequences of other events.
    The methodology question has a number of different options, depending on personal preferences. You can define actions to happen on the occurance of an event, e.g.:
    on stop_e {
       message(HIGH, "I got a stop event");
    For your method, you could do something along these lines:
    my_tcm()@c_e is {
        first of {
             sync @start_e;
             message(HIGH,"Got a start_e event");
             sync @stop_e;
             message(HIGH,"Got a stop_e event");
             sync @clk_e;
             message(HIGH,"Got a clk_e event");
    The benefit of this that the method will see two events as well.
    Cheers,
    Hilmar
