  2. Functional Verification
  3. problem with AXI uVc
  • Subscribers 67
  • Views 16037
eyal
eyal over 16 years ago
Hi all
i facing some problem setting the storbe field fo vr_axi_transfer.
the setting of a new strobe doesn't change the address offset and the data that need to be writen ? why ?
and how it can be fixed ?
more over the does the strobe aligened with the endiannity ?
Eyal
  • StephenH
    StephenH over 16 years ago
    Hi Eyal.
    Since you probably don't want to share your waveforms on the public forum, you might do best to open a service request at http://support.cadence.com/. We have engineers dedicated to supporting the protocol UVCs, so they should be able to resolve your problem very quickly once you can give them some more details, e.g. waveforms, configuration etc.
    I know the AXI UVC has been used on hundreds, if not thousands, of projects, so I expect it's a configuration issue (or possibly misunderstanding the spec) rather than a bug in the UVC.
  • eyal
     hi Stephenh
    thank for your response i manged  to solve this problem ,you were right it was a miss understanding of the spec.
    thanks again Eyal
