  2. Functional Verification
  3. eVC config_wizard
  • Subscribers 67
  • Views 16658
eVC config_wizard
spark
spark over 16 years ago
In AXI eVC package there is a config_wizard directory, it seems that it can generate configuration file automaticaly. But I dont know which tool is needed to do this generation and how do it. Would some one tell me, thank you.
  • Hilmar
    Hilmar over 16 years ago
    That works with IVB, Incisive Verification Builder. Just type ivb in a shell and you should see the GUI pop up.
    Hilmar
  • spark
    Thank you for your useful information. I run the ivb in shell, but  the following message pop,
    **** Fatal error - leaving Specman:
    Incisive Verification Builder: Couldn't acquire license -
    specman failed: Unexpected error
    License of  IUS and SPMN has no problem. Does IVB need separated license?
  • Hilmar
    Can you check whether you have licenses available? Perhaps all licenses have been checked out. You can check what's asked for by looking at the lmstat -f output. As far as I can tell, you'll need a specman license available, but I might be mistaken there.
  • spark
    I have checked the license,specman license is available.
    Users of specman:  (Total of 10 licenses issued;  Total of 0 licenses in use)
    %specman
    Welcome to Specman Elite (08.10.001-p)  -  Linked on Sat May 10 21:18:01 2008
    Protected by U.S. Patents 6,920,583; 6,918,076; 6,907,599; 6,687,662;
    6,684,359; 6,675,138; 6,530,054; 6,519,727; 6,502,232; 6,499,132; 6,487,704;
    6,347,388; 6,219,809; 6,182,258; 6,141,630; Other Patents Pending.
    Checking license ... OK
    Specman>
    But I can not run ivb, message as following,
    %ivb
    I dont know whether I should set other environment path to run IVB.
  • Hilmar
     I'm not sure, but the easiest would be to contact your local AE.
