  2. Functional Verification
  3. Sparse memory support
  • Subscribers 67
  • Views 19859
abhingp01
abhingp01 over 16 years ago
Hi all,
I need to implement quite a large amount of memory (4 GB ) in my OVC.
For which Sparse memory modelling will be most efficient one.
I am currently using Cadence IUS2.0 and need to know if cadence supports sparse memory modelling.
 I will really appresiate if you could suggest some document on "sparse memory modelling" .
Thanks in advance.
Regards
Abhishek
  • Hilmar
    Hilmar over 16 years ago
     Hi Abhishek,
    The best solution for you would likely be vr_ad.It is a very powerful package for register and (sparse) memory modelling.You can find it in either your icpm install, or the sockit, where it is packaged nowadays.
    Hilmar
  • Arun Prasad
    Arun Prasad over 16 years ago
    Hi Abhishek
    Did you implement the 4GB memory using sparse memory or by any other means. I am also looking for a similar kind of implementation. It will be helpful if you share some info on this.
    Thanks in advance
    Regards
    Arun Prasad
  • abhingp01
     Simple way is to use 'Associative arrays' from System Verilog.
     Else if you need more advanced one then go for 'regmem package'.
    http://www.ovmworld.org/contributions-details.php?id=43&keywords=An_OVM_Register_Package_V_2.0
    Abhishek
  • TAM1
    TAM1 over 16 years ago
    The simplest way to model a very very large memory in Verilog is to use the Cadence "sparse" pragma. Here's a snippet from the Cadence documentation:
    To declare a sparse array, insert the /*sparse*/ pragma anywhere within the declaration of the array or after the semicolon that ends the array declaration. For example:
    reg [31:0] /*sparse*/ mem [0:3000000];
    reg [31:0] mem /*sparse*/ [0:3000000];
    reg [31:0] mem [0:3000000]; /*sparse*/
  • Arun Prasad
    thanks abhishek :)
  • Arun Prasad
    thanks TAM1
