  2. Functional Verification
  3. SV: Coverage of assertions (only count hits??)
  • Subscribers 67
  • Views 15925
rossbthompson
rossbthompson over 16 years ago
I was under the impression that assertions would be included in functional coverage. It seems that I am only get the evaluated assertions, not ones that have not fired. Is it possible to include the un-evaluated assertions as coverage holes?
 I have multiple instances of the same checker (sv module), but I see different totals under the assertion column. I am new to SV, so it could be something basic.
Below is an example of what I see, all of the lines are instances of the same checker. The issue is that the assertion total is different
 Coverage of immediate sub-instances:
Total     Assertion     CoverGroup Weighted     CoverGroup Bins     Name
80%     100% (5/5)     60% (1)     47% (8/17)     dbxxt_dgl
73%     100% (6/6)     46% (1)     29% (5/17)     dbxxxd_det
73%     100% (6/6)     46% (1)     29% (5/17)     dbxxxt_det
73%     100% (5/5)     46% (1)     29% (5/17)     dixxrm_det
73%     100% (6/6)     46% (1)     29% (5/17)     dbxxc_det
73%     100% (4/4)     46% (1)     29% (5/17)     dxxxxxp_det
80%     100% (4/4)     60% (1)     47% (8/17)     dxxxxg_det
73%     100% (4/4)     46% (1)     29% (5/17)     dxxxxx_det
73%     100% (5/5)     46% (1)     29% (5/17)     dxxxxin_det
73%     100% (5/5)     46% (1)     29% (5/17)     dxxxxxwv_det
73%     100% (6/6)     46% (1)     29% (5/17)     dxxxxg_det
73%     100% (4/4)     46% (1)     29% (5/17)     dxxxv_det
73%     100% (4/4)     46% (1)     29% (5/17)     dxxxxt_det
73%     100% (6/6)     46% (1)     29% (5/17)     dixxxctive_det
63%     100% (2/2)     26% (1)     18% (3/17)     dxxxtive_det
78%     100% (6/6)     56% (1)     41% (7/17)     dxxxtive_det
78%     100% (6/6)     56% (1)     41% (7/17)     dxxxxxactive_det
Command:
report_html -output cov_web -all fd -inst  xxx.xxxx.*
 version 08.20-s015
  • rossbthompson
     It seems my question is fairly basic:
     If you have an assertion, how do you cover if the assertion was evaluated.
    I have tried to create a cover statement for each assert statement, but that still did not result in a coverage impact.
     I could create a covergroup for each assertion, but that seems to be overkill. Plus I am not sure how to activate the coverpoint.
