  2. Functional Verification
  3. OS signal 11 (segmentation violation) error
  • Subscribers 67
  • Views 16661
Kursi
Kursi over 16 years ago
 I got the following stack trace error in the elaboration phase, on running a test case with Intelligen.
 *** Error: OS signal 11 (segmentation violation) received
 The user view stack trace in the specman.elog file shows the following content:
 ***** User View stack trace:
( 0x0)  elaboration
( 0x1)  pre specman run
( 0x2)  specman
*** No user modules are compiled
But all the files that I have loaded have compiled properly.
Could anyone say what this error is all about and how to overcome it???
Kursi
  • StephenH
    StephenH over 16 years ago
    Hi Kursi.
    It sounds like there may be a bug in some of the e code that's being run.
    If you try to access a struct or unit that's null, then compiled Specman code will crash.
    This happens becasue the compiler optimises for performance and doesn't add null struct checks into the compiled code.
    Try either:
    1. Load your e code instead of compiling it, then type "break on error" before issuing the test command.
    2.  When compiling your ecode, add "-debug" to the sn_compile.sh command. This turns on the null struct checks, so gives you a useful message instead of a crash.
    Let us know if that solves the problem.
    For urgent support, you should always try http://support.cadence.com/ first, as often the system can offer a solution right away.
