  2. Functional Verification
  3. How to run sn_comile.sh script using IntelliGen as default...
  • Subscribers 67
  • Views 14529
How to run sn_comile.sh script using IntelliGen as default generator?
Kursi
Kursi over 16 years ago
I am currently using IUS specman 8.2 version. If I compile my top file using the sn_compile.sh script, it uses Pgen as the default generator.
Is there any option to run the script with IntelliGen?
Kursi
  • Hilmar
    Hilmar over 16 years ago
    One option is to set the environment variable SPECMAN_PRE_COMMANDS to "config gen -default_generator=IntelliGen".
    Let us know if that solved your problem.
    Hilmar
