  2. Functional Verification
  3. What type of designs can be verifyed by Formal Verifica...
  • Subscribers 67
  • Views 14594
What type of designs can be verifyed by Formal Verification
Lal Kumar
Lal Kumar over 16 years ago
What kind of designs can be verified by formal? Typical answer I get from every body is FIFOs. I have testmux design can I verify this design using formal methods?
  • Hilmar
    Hilmar over 16 years ago
     Hi Lal,
    Formal analysis in the sense of assertion based verification (not logic equivalence checking, which is also referred to as formal) can, in principle, be applied to any design. You will be constrained however by machine capacity, runtime and sometimes tool capabilities. The number one I'd pick for formal verification would be control logic. Its functionality, however large and complex, can often be described with a relatively straightforward set of properties and the runtimes in general are quite good. Another part where I like to employ formal is interface verification, for example AMBA busses. Cadence also offers assertion based verification IPs for AMBA protocols, developed for formal analysis. If you have some of your own protocols, they are often described in good protocol specs, which can often be translated into a very good set of properties.
    I hope this helps a little.
    Hilmar
  • lokesh123
    lokesh123 over 15 years ago
    Hi Lal,
    I think in the past we have interacted. Pls call me @9980045594, so that we can discuss more on IFV or you can provide me your contact details.
    Lokesh.
