  2. Functional Verification
  3. I2C BFM
  • Subscribers 67
  • Views 16889
I2C BFM
thescreen
thescreen over 16 years ago
hello
i am trying to use a free-of-charge verifcation IP from http://syswip.com cadence IUS08.20.001 and i am facing some issues i already contacted the authors (they support VCS: you may want to get the complete files from the URL above, it is free code, i do not think there are problems with that (registration is required, though)
i2c_vip/verification_ip/master/i2c_m.sv
- i had to comment lines 489, getting
     dataOutBuff = {};
ncvlog: *E,ILLPRI (.../i2c_vip/verification_ip/master/i2c_m.sv,489|19): illegal expression primary [4.2(IEEE)].
here is the chunk of code involved
  task readData(input int address, output bit8 dataOutBuff[$], input int lenght, genStop = 0);
    this.tr         = new();
    if(this.cfg.addrMode == 1) begin
      // 10 bit address mode
      this.writeData({6'b011110, address[9:8]}, {address[7:0]}, 0);
      this.tr.address = {6'b011110, address[9:8]};
      this.tr.genStop  = 1;
    end else begin
      // 7 bit address mode
      this.tr.genStop  = genStop;
      this.tr.address   = address;
    end
    TrNum++;
    this.tr.TrType  = I2C_m_busTrans::READ;
    this.tr.TrNum   = TrNum;
    this.tr.dataBuff = new[lenght];
    this.tr.dataLength = lenght;
    this.trInBox.put(this.tr);
    this.trOutBox.get(this.tr);
>>>>>>   dataOutBuff = {};
    for (int i = 0; i < lenght; i++) begin
      dataOutBuff[i] = this.tr.dataBuff[i];
    end
    this.tr = null;
  endtask
- as well as lines 128 and 135
    this.rand_mode(1);
ncvlog: *E,INAPFS (.../i2c_vip/verification_ip/master/i2c_m.sv,128|17): Inappropriate prefix for the specified built-in task/function.
    this.rand_mode(0);
ncvlog: *E,INAPFS (/i2c_vip/verification_ip/master/i2c_m.sv,135|17): Inappropriate prefix for the specified built-in task/function.
and here is the code
  task setRndDelay(int t_max, rndLevel);
    this.t_max    = t_max;
    this.rndLevel = rndLevel;
    this.c_timing.constraint_mode(1);
>>>>    this.rand_mode(1);
  endtask
  /*- setTiming(): Set I2C bus custom timing.*/
  task setTiming(time t_Low, t_High, t_HoldStart, t_SetupStart,
                              t_HoldData, t_SetupData, t_Buff, t_Valid, t_SetupStop);
>>>   this.rand_mode(0);
>>>    this.constraint_mode(0);
    this.t_Low        = t_Low;
    this.t_High       = t_High;
    this.t_HoldStart  = t_HoldStart;
    this.t_SetupStart = t_SetupStart;
    this.t_HoldData   = t_HoldData;
    this.t_SetupData  = t_SetupData;
    this.t_Buff       = t_Buff;
    this.t_Valid      = t_Valid;
    this.t_SetupStop  = t_SetupStop;
  endtask
I cannot understand why it cannot use the 'this'  in that context, since the standard says
"The this keyword is used to unambiguously refer to properties or methods of the current instance. The this eyword denotes a predefined object handle that refers to the object that was used to invoke the subroutine that his is used within. The this keyword shall only be used within non-static class methods, otherwise an error hall be issued. For example, the following declaration is a common way to write an initialization task:"
After i commented them out that, i then got a crash
ncvlog: *F,INTERR: INTERNAL ERROR
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL: ncvlog  08.20-p001
  HOSTNAME: bigshow
  OPERATING SYSTEM: Linux 2.6.9-55.ELsmp #1 SMP Fri Apr 20 16:36:54 EDT 2007 x86_64
  MESSAGE: vst_identifier () - bad class, class 581
it looks like
is the cause of the crash!
but according to section 12.2 od SV 31, standard i see it is correct appearently
thanks
  • StephenH
    StephenH over 16 years ago
    Hi.
    If you haven't already done so, can you try using a more up to date version of IUS? The one you've reported in your message is very old now. If possible, try the latest 9.2 hot-fix version.
    If that still doesn't work, please use http://support.cadence.com to file a service request, and someone from Cadence support will help resolve the issue for you.
    Thanks.
  • thescreen
     thanks: i already opened a case #41881528 with cadence support
    in the meantime i asked my IT to update IUS
    cheers
