  2. Functional Verification
  3. cannot simulate $fscanf (ncsim asks for vpi)
  • Subscribers 67
  • Views 16677
thescreen
thescreen over 16 years ago
I am trying to used fscanf and other fileio which are verilog 2001 compliant (IEEE Std 1364-2001 Version C section 17.2.4.3
describes $fscanf and $sscanf.)
ncvlog and ncelab works fine. ncsim is asking to include a vpi (using -loadvpi)
what should i do? i can't believ IUS 8.20 does not support the 2001 standard (vintage 2001 indeed ...)
thanks
  • muffi
    muffi over 16 years ago
     Both these constructs are very much supported. Can you please post a snippet of the error message?
  • thescreen
    here you go
    thanks
     Loading snapshot tbench.tb_snapshot:module .................... Done
                  $frewind(file_ptr,"%h\n",ADC_DOUT);
    ncsim: *E,MSSYSTF (/prj/vdt/USERS/stanzani/SN/TCR1/design/top/core/RX_ISM/beh/RX_ISM.v,153|14): User Defined system task or function registered during elaboration and used within the simulation has not been registered during simulation.
  • TAM1
    TAM1 over 16 years ago
    I'm afraid that $frewind is not part of the IEEE standard.
    $rewind is, but it's only argument is the file descriptor: "$rewind(file_ptr);"
  • thescreen
    thanks for the hint, works fine!
