  2. Functional Verification
  3. Disabling illegal coverpoint check?
  • Subscribers 67
  • Views 15667
rossbthompson
rossbthompson over 16 years ago
I have a "test mode" test that creates illegal values. I am using assertkill for this test to kill off assertions, but the covergroups are still activating and causing fails.
EX:
ncsim: *E,EILLSC: Sampled value (15) for coverpoint (mon_state) of cross (digtop_tb.xxxxx.shut_except) is an illegal value.
 Is there an equivelent to assertkill to disable these?
 I am using version: 8.20.015-s
Ross
  • TAM1
    TAM1 over 16 years ago
    You can use the built-in covergroup methods to disable sampling.
    mycovergroup group1 = new();
    initial
    begin
       group1.stop();
       group1.start();
    endgroup
    You could also use a global signal and the "iff" clause in a covergroup declaration to control more than one covergroup at a time.
    reg illegal_packet_ok = 0;
    covergoup moncover @(posedge clk);
       coverpoint mon_state iff ( ! illegal_packet_ok ) ...
    There are a lot of places in the covergroup syntax where you can place the iff-clause to turn off a portion of the covergroup, a portion of a coverpoint or a portion of a cross. So you can experiment to see exactly where and when you want to disable the collection of data for an illegal packet.
