  2. Functional Verification
  3. out of memroy
  • Subscribers 67
  • Views 15261
out of memroy
genius30mc
genius30mc over 15 years ago
I get the following error message:
 ERROR: Unable to allocate memory for transition file slice variable transition index level (read).
I run under linux,
                    total       used       free     shared    buffers     cached
Mem:      24669304    3699124   20970180          0      77792    2174028
 I should have enough memroy left,
SimVision 08.20-p001
any help help is welcome
Heinz
  • TAM1
    TAM1 over 15 years ago
    You may need to go to the 64 bit version of the simvision tool if the transition file is too large to be read into the 32 bit version. Also, 8.2-p001 is really old software. I'd strongly encourage you to download and use the latest version of the software from Cadence. There have been a lot of changes and fixes in the year+ since p001 was released.
  • ajukrishnan
    ajukrishnan over 12 years ago
     I was also getting OUT OF MEMORY error when trying to source sommand script I had saved earlier in simvision. It got solved when I used 64 bit version of my simvision 9.20-s017. Thank you.
