  2. Functional Verification
  3. loading VHPI library on irun
  • Subscribers 67
  • Views 16861
yongh
yongh over 16 years ago
I am trying to load vhpi library for irun simulation. I used -loadvhpi option but it doesn't seem working correctly. even I cannot see loading failure messages. Could you please help me how to load vhpi library on irun? This VHPI library was used for ncsim. Can I use the same so file for irun as well?
Yong
  • TAM1
    TAM1 over 16 years ago
    I think we need to see more information. What does your irun command line look like? What was the error message in the log file? Do you have a bootstrap routine to register your vhpi procedures?
  • yongh
    Thanks, your reply. The irun command is 'irun -unbuff -loadvhpi vhpi_lib_ncsim:initialise -r snapshot'. The problem is I don't see any error messages from irun, also no messages regarding vhpi. When I use ncsim I could see some initialization messages and error messages if I set wrong vhpi information. They don't appear in irun.
  • TAM1
    We've still got next to nothing to go on. My guess would be that, since you are reusing an existing snapshot, you'll need to make sure that all the command-line options on irun that can affect where or how that snapshot is loaded will need to exactly repeat those used when the snapshot was first created.
    I've seen problems where things like -libdirname had to be repeated when a snapshot is rerun. Maybe the same is true for loading VHPI libraries.
    Beyond that, I personally don't have much to offer.
  • StephenH
    StephenH over 16 years ago
    What Yong didn't tell us was that he's using irun in 3 steps (irun -copile; irun -elaborate; irun -r).
    He was passing -loadvhpi only to the final stage (irun -r), but it looks as though the problem was solved by adding -loadvhpi to the elaboration stage as well.
    In general I'd recommend to be consistent about passig the same set of args to irun at each stage. More specifically I'd recommend not try to force irun to work like the old-fashioned 3-step ncvlog/ncelab/ncsim flow.
    Yong, if I missed anything from our email exchanges, please would you share this with the forum so others can benefit from it?
  • yongh
    Thanks, StephenH
     Actually I was investigating something before posting because I was not using '-elaborate' option. I thought it's logically elaboration stage but in fact it compiles and elaborates the top-level testbench with '-top' and '-c' although there are some compilation stages for a number of IPs as libraries. I put '-loadvhpi' option in the stage of elaboration happening and it works with running simulation with the same '-loadvhpi' and '-r'.
     I am trying to really separate the stages with -elaborate option for just personal interest but I have not made it working. :-) Maybe I can add some more info if I find any interesting.
    Thanks a lot for your help, guys
