  2. Functional Verification
  3. using ncverilog with synthesized ".vo" files from alter...
  • Subscribers 68
  • Views 2716
using ncverilog with synthesized ".vo" files from altera
sbeling
sbeling over 16 years ago
I am trying to use an existing testbench and would like to use synthesized (.vo) files from altera. The issue that I am running into is that some of the test bench code (in files which are compiled by ncvlog) access signals which are in the .vo file. ncelab can't find the signal -- it gives "Hierarchical name lookup failure"  -- Has anyone done anything like this ?
  • Mickey
    Mickey over 16 years ago
    what does the *.vo file look like? is it some kind of encrpyted or proprietary format? or is it a regulat verilog gate netlist?
  • sbeling
    It is a regular netlist -- and does work with the simulator, it is just that the internal signals are not visible when directly referenced
  • Mickey
    Can you send an example (jrodrig@cadence.com)? i don't see why the signals can't be found via an out-of-module reference
  • TAM1
    TAM1 over 16 years ago
    The most likely cause was that Altera (or whatever the synthesis tool was called) did not preserve the net names in the synthesized netlist. It could be that the netlist is flattened from the RTL hierarchy or that the signals you are trying to probe have been optimized away.
    There are usually commands you can add to your synthesis scripts that tell the tool to preserve the hierarchy and/or RTL signal names. But you usually end up with a less efficient synthesized netlist at the end when you do that.
  • sbeling
    That was the problem (Mickey sent me the flattening in private email).
    Thanks all
    Steve
