  2. Functional Verification
  3. how to run ovm cookbook example by IUS?
  • Subscribers 67
  • Views 15950
RomanDW
RomanDW over 16 years ago
 Hi all,
i can run the ovm cookbook example by default Questa, but i try to wirite a 'compile_ius.f' file, and use 'irun -f compile_ius.f' to run the ovm-examples-1.1\07_complete_testbenches\02_rtl case, but meet many errors.
who can help me release the 'compile_ius.f' based on following questa follow?
i want to run it following irun flow.
thanks
in compile_questa_sv.f
-suppress 2223
+incdir+../../hfpb
+incdir+../../fpu_sv
+incdir+../../hfpb_components
+incdir+$OVM_HOME/src
$OVM_HOME/src/ovm_pkg.sv
../../fpu_sv/float_pkg.sv
../../fpu_sv/fpu_util_pkg.sv
../../fpu_sv/fpu_tlm_pkg.sv
../../fpu_sv/fpu_pin_if.sv
../../hfpb/hfpb_if.sv
../../hfpb/clock_reset.sv
../../hfpb/hfpb_pkg.sv
../../hfpb_components/ctypes.sv
../../hfpb_components/hfpb_components_pkg.sv
top.sv
in compile_questa_vhdl.f
../../fpu_vhd/fpupack.vhd
../../fpu_vhd/comppack.vhd
../../fpu_vhd/addsub_28.vhd
../../fpu_vhd/fpu.vhd
../../fpu_vhd/mul_24.vhd
../../fpu_vhd/post_norm_addsub.vhd
../../fpu_vhd/post_norm_div.vhd
../../fpu_vhd/post_norm_mul.vhd
../../fpu_vhd/post_norm_sqrt.vhd
../../fpu_vhd/pre_norm_addsub.vhd
../../fpu_vhd/pre_norm_div.vhd
../../fpu_vhd/pre_norm_mul.vhd
../../fpu_vhd/pre_norm_sqrt.vhd
../../fpu_vhd/serial_div.vhd
../../fpu_vhd/serial_mul.vhd
../../fpu_vhd/sqrt.vhd
in run_questa
vlib work
vlog -f compile_questa_sv.f
vcom -f compile_questa_vhdl.f
vsim -suppress 2223 -do vsim.do -c -suppress 3829 top
  • StephenH
    StephenH over 16 years ago
    Hello Roman.
    I'm not familiar with the cookbook examples. You might try looking at the examples that ship with OVM itself, as these have compile scripts for both Questa and IUS.
    Most of the options you're passing to Questa can be passed directly to irun. Note that if you add the -ovm switch to irun, you don't have to compile the OVM package directly. I can't recall off-hand if this makes it compile better or not! :-)
    Try something along the lines of this:
    Where compile_ius.f contains:
    -ovm
    +incdir+../../hfpb
    top.sv
    If that doesn't work, it'd help if you posted the (first) error message that you get from irun.
  • Glyconutrients
    Glyconutrients over 16 years ago
    Its very interesting to know that how to run cookbook examples ........
    There will be a cookbook with OVM like what Mentor had with AVM i.e. something that explains the reasoning behind the methodology used etc...
  • Team genIES
    Team genIES over 16 years ago
    You may also want to track the UVM work at the Accellera VIP TSC where the OVM User Guide will serve as the basis for the UVM methodology guide.
     =Adam Sherer
  • pcarzola
    pcarzola over 16 years ago
    You may also want to take a look at the OVM based workshops that come with Incisive Enterprise Simulator. These workshops come with slides, labs and real working reference environments. If you log into http://support.cadence.com You can see the available material here as well: http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=soc_intro/soc_intro9.2/v_Solutions.5.4.html#1150418
