  2. Functional Verification
  3. VHDL & SystemVerilog Connection
  • Subscribers 67
  • Views 1345
ssan
ssan over 16 years ago
Hi all,
I have in the design a signal which is defined:
SIGNAL win_energy_array   :  std_energy_array;
in the package defined:
CONSTANT NUM_OF_FIRS                :INTEGER                         := 5;
CONSTANT ENRG_MAX_BIT               :INTEGER                         := 10 ;
TYPE std_energy_array IS ARRAY (NUM_OF_FIRS DOWNTO 1) OF STD_LOGIC_VECTOR(ENRG_MAX_BIT DOWNTO 0);
I have imported the package and defined a program,
I tried to use the type std_energy_array  as an input signal type and I got the error: unknown identifier,
so I tried to define:
import pre_proc_lib::*;
program fb_fullchip_tb
     input  logic[5:1] win_energy_array [10:0];
and tried to bind them:
program bind_prog;
 bind PreProc fb_fullchip_tb fb_tb
      .win_energy_array(win_energy_array)
I also tried the following:
input  logic[5:1] win_energy_array [10];
input  logic[5:1] [10:0]win_energy_array ;
But I always get the error:
# ** Error: (vsim-3055) Type of connected VHDL signal is incompatible with Verilog port 'win_energy_array'.
The other signals in the program are connected all right.
How should I define my this signal?
