  2. Functional Verification
  3. *F,LCFAIL: (LM -4) ....
  • Subscribers 67
  • Views 2460
mmk23
mmk23 over 16 years ago
Hi All, I'm facing issue in invoking simvision. Giving following Fatal error msg. *F,LCFAIL: (LM -4) Unable to obtain a license for version 9.2 of feature 'Affirma_sim_analysis_env' in any license file (run 'lic_error -4' for more information) SimVision process terminated before a connection could be established. ncsim: *E,STRPIN: Could not initialize SimVision connection: SimVision process terminated before a connection was established. We still have enough license but the above msg is coming. When switched to some other server its working fine but after sometime again. the same problem exists. Does anyone come across similar problem ? Any solutions to this ? Thanks, mmk23
  • StephenH
    StephenH over 16 years ago
    You need to request that the licence keys are updated to version 9.2, which either goes through your IT/CAD dept, or you can do it via http://support.cadence.com/.
