  2. Functional Verification
  3. starting an executable from specman, how to ?
  • Subscribers 66
  • Views 15117
archive over 16 years ago
hi all
i need to start a golden model that comes as an excutable (i dont have the source code) from specman is there  a way to do so ? (may be as a shell command)?
i dont have the source code or the .o/.so files so i cann't use the the c interface.
Regards Eyal
  • StephenH
    StephenH over 16 years ago
    You can start any Unix command via the spawn() or system() methods in Specman.
    The question is, once the C model is running, how does it communicate with the simulation?
    Does the model just read a data file, and dump a golden output file?
    Or does it have a socket interface to talk to Specman?
    There are lots of options, depending on what your C model can do...
    hi Stephen
    thank you for your response, i have figured it out also after some digging in the cdnshelp pages and come across the spawn & system commands as well.
    the golden model only dump the result to files so there is no need for communication with the simulation.
    thanks again Eyal.
