  2. Functional Verification
  3. Vexp source causes Allegro to crash
  • Subscribers 66
  • Views 13555
fmacc
fmacc over 15 years ago
Problem first occurred in Feb. 2009.  No resolution from Cadence or local
Admin.  If you place a Vexp source on a schematic, connect it, define its'
parameters and start to run the simulation you get a crash that closes
the schematic tool (Allegro HDL).  Cadence sent a model library that included
Vexp and when it is in the local library no problem exists.  Running 16.2 but
same issue existed with 15.7.  In one Vexp dir. there is both an VHDL and Verilog
file.  The one that fails has only the Verilog file.  Need to figure out what files
are being accessed when crash occurs.  The message you get asks if you want
to zip the project and send it to Cadence.  Did this in Feb. 2009 and was told
they could duplicate the problem and it would disappear in 16.2.  It didn't and
I'm still looking for a solution.  I don't have admin privileges so I can't substitute
the files that Cadence sent in their archive.  I'm assuming there is a corrupt file
in the Vexp directory but not sure.  Any ideas?
Fred
