  2. Functional Verification
  3. Tracking signal values in simvision
  • Subscribers 68
  • Views 18048
bgpradeep
bgpradeep over 16 years ago
I am new to using simvision for simulation debug and would like to know how can i track the signal value change in the "Source Browser" when i clikc on that signal edge in the "waveform window".
 If i try this now i donot see any change in the signal values inside "Source Browser".
  • Tikesh
    Tikesh over 16 years ago
    Hi Pradeep,
    If you click on the signal edge, in the waveform window you should see two values in the source browser. One value before the edge and second one after the edge.
    For example if your singnal is changing from 0 to 1 in the waveform window and you click on its edge you should see '0 -> 1' in the source browser. Let me know if it is helpful.
    Tikesh
