  2. Functional Verification
  3. Reading SVSEED set by IUS,vamanger
  • Subscribers 68
  • Views 4610
adwait
adwait over 16 years ago
When the job is submitted to queue via vmanager and seed is set by IUS how to read that seed inside .sv or .v file. When I read it with $value$plusargs it returns warning saying the
the types do not match and +svseed value is 'random'. Is there anything available to get that seed directly ?
  • sumg
    sumg over 8 years ago +1
    Is there a way set SVSEED in the interactive session of NCSIM? So far I have been doing this with "reinvoke simulator" option and editing irun -seed command argument in the reinvoke dialogue box. …
  • StephenH
    StephenH over 16 years ago
    Normally you should not need to access the seed directly yourself, as NCSim takes care of seeding the SV RNG directly from the -svseed argument.
    If you really need to get the seed value yourself for some other purpose, then I'd recommend you use the "gen_random" value in the VSIF. This asks vManager to generate a random numeric seed before calling the test's run_script. For example:
    test my_test {
      sv_seed : gen_random;
    Hope this helps.
  • sumg
    I have observed that when we "reset" simulation to time zero. I get the message "SVSEED set from command line: XXXX"
    Is there a "ncsim> " command to do this in an easier way and avoid time consuming reinvoking simulator option?
  • Damn
    Damn over 7 years ago in reply to sumg
    I haven't seen any reply to this question... reinvoking the simulator is slow and often crashes. Does anyone know another way in simulator console to change the svseed?
    e.g. with specman you would rerun a test with a different seed using : ncsim> reset; sn reload; sn test -seed=random; run
    You might do that in interactive simulation to check your test works with at least one other seed.
    What's the equivalent in SV UVM?
