  2. Functional Verification
  3. help with e *** Error: list is empty - cannot access item...
  • Subscribers 67
  • Views 1736
help with e *** Error: list is empty - cannot access item 0
JAbusaid
JAbusaid over 16 years ago
I have the following structure:
struct collector_txn_s like any_sequence_item {
    kind : trans_kind_t;
    keep soft kind == GENERIC;
    %data    : list of byte;
When I do the following:
    private send_odt()is {
      transfer = new GENERIC collector_txn_s with{
       for each (d) using index (byte_idx) in smp.D_sig_l {
        it.data[byte_idx] = d.get();
I get the  Error: list is empty - cannot access item 0 error.
Any ideas why this might be happening?
  • StephenH
    StephenH over 16 years ago
    Have you tried stepping through the code in the debugger, to see which line triggers the error?
    You might need to set the list size, because you're using a "new" action here, not a "gen" action. Whilst "gen" will allocate randomly all the lists, I believe "new" will not allocate anything that you have not explicitly asked it to do. In effect the code in the "with" block is just the same as putting it all as procedural code, thus:
    transfer = new GENERIC collector_txn_s;
    for each (d) using index ... { ... };
