  2. Functional Verification
  3. AXI eVC for 512-bit data width
  • Subscribers 67
  • Views 15076
spark
spark over 16 years ago
Hi All,
When I define VR_AXI_MAX_DATA_WIDTH to 512, the specman will report error duing compile,
*** Error: Illegal cover item 'strobe'. It is of type 'vr_axi_strobe_t',
but cover items can only be scalars (of size <= 32 bits) or strings
                at line 772 in /opt/cadence/VR_LIB/vr_axi/e/vr_axi_coverage.e
        item strobe: vr_axi_strobe_t = ended_burst.transfers[0].strobe using
It seems that e coverage item should not be larger than 32-bit, is it? Is there any method to define a 512/1024-bit data bus for AXI eVC? AXI eVC version is 01.40.001-p.
Thanks in advance.
  • StephenH
    StephenH over 16 years ago
    The AXI eVC has some define options to disable certain bits of coverage for huge busses. You should try:
    define VR_AXI_LARGE_STROBE;
