  2. Functional Verification
  3. passing IRUN command-line arguments into vsif file?
  • Subscribers 68
  • Views 23732
xzhao
xzhao over 16 years ago
I use command-line arguments in my script and it looks like this
irun ... +define+MY_ARG ...
I can run stand-alone simulation with different MY_ARG to different tests.
How can I reuse my script in a vsif to launch regression of all tests? Is there a way to define an attribute so I can specify MY_ARG in vsif, for example
test my_test1 { my_arg_attr : 2};
test my_test2 {my_arg_attr : 3};
Thanks for help.
Xing
  • moogydmaxim
    moogydmaxim over 12 years ago
    Hi Xing,
    Did you work out how to do this - I want to do the same thing - basically pass testname to my run_sim script.
    Steven
  • StephenH
    StephenH over 12 years ago
    You can pass attribute valuesto your run script using the $ATTR(<name>) or $RUN_ENV(<envvarname>) in theVSIF.
    Look in the cdnshelp tool for more information about attributes, how to deine them and pass them around.
    Here's a small example from the SoC Verification Kit labs that ship with Incisive:
    group apb_ss_tests {
      run_script: "irun -R -nclibdirname $DIR(chain)/INCA_libs +UVM_TESTNAME=$ATTR(test_name)_test -covtest $ATTR(test_name)";
      scan_script: "vm_scan.pl shell.flt uvm.flt ius.flt";
      count : 5;              // Default run count
      sv_seed: random;       // Random seed selection
      test apb_subsystem { };
      test apb_gpio_simple { };
      test apb_spi_simple {  };
      test apb_uart_simple { };
  • moogydmaxim
     Hi Stephen,
     Thanks -exactly what I was looking for.
    Steven
  • Subhash Sangam
    Subhash Sangam over 8 years ago in reply to StephenH
    Hi Steven, Could you provide me with an example on how to send attributes other than test_name. For example, my run script in standalone mode accepts -opts
     ../scripts/run.sh -test i2c_basic_trans_test -opts "+VSEQ=HP_RD"
    While running another test I want to change "+VSEQ=HP_RD" to "+VSEQ=LP_RD"
    Thanks in advance.
