  2. Functional Verification
  3. eVC integrated with sv-ovm verification environment.
  • Subscribers 67
  • Views 14842
arjuny
arjuny over 16 years ago
    I would like to build verification environment using SV-OVM. I have AXI eVC and this needs to be used in the SV-OVM.
    How can i integrate this AXI eVC to the SV-OVM verification environment?
    Can anybody point me to some documents where this integration is mentioned.
    AXI will be acting as Master and the dut as slave.
Thanks & Regards,
Arjun.
  • StephenH
    StephenH over 16 years ago
     What you're looking for is the utility "OIG" that ships with Incisive. Its full title is OVM Interface Generator.
     This utility helps you to wrap an eVC with a SV API, so that you can use it in an OVM-SV testbench.
    Search for OIG or OIC (OVM Interface Configurator) in the cdnshelp tool.
    You might want to talk to your local Cadence AE who can guide you through the process (ping me your email address if you want help finding your local AE).
